I have a register which holds 12 bits written in VHDL within Vivado which is not being gated properly. The code is very simple, and is as follows:
library ieee;
use ieee.std_logic_1164.all;
entity reg12b is
    port (
        reg_in : in std_logic_vector(11 downto 0);
        load, clock, clear : in std_logic;
        reg_out : out std_logic_vector(11 downto 0)
end reg12b;
architecture description of reg12b is
    signal internal_value : std_logic_vector(11 downto 0) := "000000000000";
begin
    process (clock, clear, load, internal_value)
    begin
        if rising_edge(clock) then
            if (clear = '1') then
              internal_value <= "000000000000";
            elsif (load = '1') then
                internal_value <= reg_in;
            else
                internal_value <= internal_value;
            end if;
        end if;
    end process;
    reg_out <= internal_value;
end description;
As you can see, this holds 12 bits, and has a synchronous reset function. This is what it synthesizes to in Vivado. As you can see in the blue highlighted line, the Flipflop is an input to the LUTs, but another input to the LUTs is the inputs. I've tried refactoring my code a large number of times, and it never seems like I can put the flip flops as the sole output.
The code produces strange setups akind to the picture below. This sort of construction is not desirable, as it creates large timing hazards across the entire design. enter image description here
I want the entire design to be gated, moreso as follows: enter image description here
How do I tell Vivado that I want it to design the second picture, and not the first picture?
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – Voltage Spike
    Jun 9 '20 at 18:42
