I'm trying to develop a Verilog code for right shifting as a part of Floating Point ALU. I'm getting the following error in line 7:
Error: HDL-Complier-661 .... Non net port cannot be mode of input
Please tell me what my error is and provide me with corrected code.
        `timescale 1ns / 1ps
    module right_shifter(small_mant, shift_amt, shifted_mant);
    input [3:0] small_mant;
    input [2:0] shift_amt;
    output [5:0] shifted_mant;
    reg [3:0] small_mant;
    reg [5:0] shifted_mant;
    always@(small_mant or shift_amt)
    case (shift_amt)
    3'b000: shifted_mant <= {2'b01, small_mant[3:0]};
    3'b001: shifted_mant <= {3'b001, small_mant[3:1]};
    3'b010: shifted_mant <= {4'b0001, small_mant[3:2]};
    3'b011: shifted_mant <= {5'b00001, small_mant[3]};
    3'b100: shifted_mant <= 6'b000001;
    default: shifted_mant <= 6'b000000;
    endcase
    endmodule
Verilog does not allow input ports declared as a variable with a data type (SystemVerilog does).You can remove that line. I also suggest using a simpler form of port declarations that only mentions each port name once instead of up to three times (called ANSI style in the IEEE LRM)
    input [3:0] small_mant,
    input [2:0] shift_amt,
    output reg [5:0] shifted_mant
  • \$\begingroup\$ This worked . Note that we have to use comas, instead if semicolons. module right_shifter( input [3:0] small_mant, input [2:0] shift_amt, output reg [5:0] shifted_mant ); \$\endgroup\$ May 7 '20 at 10:26
You've declared your port as input [3:0] small_mant; - this means you are declaring an input to the module, which must be of a net type (a.k.a. a wire).
However you then re-declare your input port as reg [3:0] small_mant; which is a variable data type (reg), and therefore not a net type.
You cannot, and in fact never need to, declare an input as a reg, so simply remove that line.
The corrected code :-
//Module: Shifts a given numner to the right by an amount (shift_amt)
case (shift_amt)
endcase
endmodule
