I have a circuit that runs on 1V up to 15V DC. I want to attach a low-power battery-level (1.5V) device to this supply rail, and have it work over the broadest input range possible (yes, it will cut off before 1V most likely, but I’m okay with that). The device cannot take an input of more than 5V, and preferably I’d like it to not go higher than 2V or so. It draws on the order of 1µA or less current.
It seems like one simple way to accomplish the goal of limiting voltage and operating as close to the low end as possible is to put a JFET (N-channel) between the supply and the device, with its gate tied to ground. If the JFET’s threshold is around 2-3V, then once the supply (drain side) goes high enough, the JFET’s resistance will go up, keeping the source side from going higher than about 2V above the gate (ground), and there will still be enough current to power the device. On the source side (i.e. where the device is) I can put a resistive load if the draw isn’t consistent enough.
What I’d like to know is if there is any obvious flaw in this plan, or reason that it might not work as intended. Of course this is highly dependent on the variable pinch-off voltage, but bear in mind I don’t need a precise level; just a way to make sure the voltage doesn’t go too high for the device. I’m only making a few of these, so I can likely tweak a too-high threshold with the load on the device side; I can easily spare up to a few 100 µA without it affecting the rest of the circuit.
