I'm trying to design a MOSFET based switch which allows a sinewave through, however I noticed that when I was simulating it in LTSpice, whenever I try to turn off the FET the negative half of the sinewave still passes through.
Why is this and how do I prevent this from happening?
    \$\begingroup\$ Are you aware that FETs contain an internal body diode? \$\endgroup\$
    – Hearth
    May 6 '20 at 20:55
Note that the source and body of your MOSFET are internally connected together. When you apply a negative voltage to the drain you will forward-bias the internal PN junction between the MOSFET body (p-type) and the drain (n-type).
You might want to just use an analog switch that is designed for this purpose rather than build your own.
