In the lines wherever I try to do the assignment of value, the above error pops up. Please tell me what's the mistake and guide me with the corrected code snippet.
`timescale 1ns / 1ps
module big_small (
input [3:0] mant_A,
input [3:0] mant_B,
input [3:0] exp_diff,
input exp_diffsig,
input mant_diffsig,
output [3:0] big_mant,
output [3:0] small_mant
always@(*)
if (exp_diff == 4'b0000)
begin
big_mant <= (mant_diffsig)? mant_B: mant_A;
small_mant <= (mant_diffsig)? mant_A: mant_B;
end
else
begin
big_mant <= (exp_diffsig)? mant_B: mant_A;
small_mant <= (exp_diffsig)? mant_A: mant_B;
end
endmodule
    \$\begingroup\$ left-hand side should be reg/integer/time/genvar - the left hand side of the <= assignment must be one of those four types. Is it? \$\endgroup\$ May 7, 2020 at 11:04
The error says left-hand side should be reg/integer/time/genvar - in other words, on the line indicated, the left hand side of the <= assignment must be one of those four types.
Your left-hand side is declared as output big_mant (same goes for output small_mant) which are of type wire. You cannot do a procedural assignment (assignment inside an always statement or initial block) to a wire type as the error message has told you.
Change the two outputs to output reg types if you wish to use them as the left hand side of a procedural assignment statement.
