I am using Mosfets to power an RGB LED light strip with a Raspberry Pi:
https://www.sparkfun.com/datasheets/Components/General/RFP30N06LE.pdf
The I though the threshold voltage for the above Mosfet was low enough for the 3.3V supply from the Raspberry Pi to the gate pin but the LEDs are dim (the blue is the dimmest maybe because of different internal resistance in the strip?). I measured the voltage across the drain and source for each of the 3 Mosfets (red, blue, and green) at 7, 6, and 5 volts respectively. I attached the gate pin to the 5V pin on the Raspberry Pi and the lights lit up full brightness. Is it possible to wire up a circuit that uses the Mosfet's I currently have in place at 7, 6, and 5 volts to control the gate pins of three other Mosfets that then power the lights? i.e. I want to open a Mosfet's channel from Drain to Source by providing voltage to it's gain pin from another Mosfet's output. If not possible, is there something I could be doing wrong with the wiring or do I ultimately need to find another Mosfet with even lower threshold voltage? Below is the fritzing diagram I have been using with a 100k pull-down resistor. Power Source is a 12VDC 1A supply
