I'm using the L6201PS H-bridge to drive a 48V DC motor and I broke one of the H-bdridges (when I drive it in the forward direction now, both OUT1 and OUT2 are 48V instead of OUT1 at 48V and OUT2 at GND. When I drive it backwards, it's still working properly) by accidentally using a faulty connector that had the motor terminals +/- shorted together. There was a popping sound as soon I tried to drive the motor.
I was a bit surprised since this chip has thermal shutdown as one of its selling points: "A thermal protection circuit has been included that will disable the device if the junction temperature reaches 150 °C".
My thought was that as the H-bridge starts to short circuit, the junction temperature would rise very quickly and then it would go into thermal shutdown, saving itself from permanent damage - however based on this recent experience I'm starting to wonder if this is not true. Does thermal shutdown not provide protection against short circuits ?
    \$\begingroup\$ It does not, thermal protection expects a slower temperature rate increase, while a short not only spikes the temperature very fast, but spikes the current too. Also the thermal protection is not effective for only 1 small part of the IC that burned, it's effective for the whole ic together. \$\endgroup\$
    – CFCBazar
    Commented May 8, 2020 at 6:43
The thermal timeconstant of a cubic meter of silicon is 11,400 seconds,
The thermal timeconstant of 1 cubic millimeter of silicon is 1,000,000X faster, at 11,400 microseconds or 11.4 milliSeconds.
Typically the die are thinned (from 300 microns in raw form) to 100 microns. The thermal timeconstant of 100 microns is 100X faster at 0.114 milliSeconds.
Unfortunately, unless the over-temp-detector is imbedded into the power-device (not off to the side), the power region can melt before the detector "detects" its_too_hot.
Even if the device is operating at 25 ° C, and a short occurs, the rate of heating between the top and bottom of the silicon will be far too fast to be detected by some "diode" off to the side.
I performed some thermal modeling 15 years ago, that showed the "temp detector" needed to be no further than 10 microns from the periphery of the power device, and preferably placed within a niche , or even in the middle of the power device.
As you've seen, the magic-smoke gets to escape (or that horrid "click" sound gets emitted as the plasma ball expands and ruptures the epoxy lid).
There is a severe interference issue in "temperature detectors" on power devices. Unless the "diode" runs at high current (milliAmps), the dynamic resistance will be high and the diode voltage easily upset from charges injected INTO THE SUBSTRATE or from EFIELDS coupled metal-to-metal on surface of the die.
======================== May 11
Where to read about such topics? I'm going to say "Its just simple physics", and visualizing cubes of material with uniformly_flowing columns of heat.
I recall ONE article in Journal of Solid State Circuits (the Red Rag) where the placement of the bias_generator transistor was computed, and the math for 100 micron grid size was agreeing with my math (within the use of physical constants for silicon at room temperature but from different text books).
About 25 years ago, I was simulating Substrate Currents for silicon, to develop very quiet working regions on very_trashy_integrated_circuits (you need nested Substrate Shields).
And I soon realized, at the next job, I could model Heat Flows, important because my first new assignment was a data bus power driver with the need to survive 8:1 overvoltages. But the Thermal Protection did not work.
Developing the theory, I computed the Thermal TimeConstant of 10micron silicon spacing was 1.14 uS, of 100micron spacing was 100X slower, and of 1,000 micron spacing (about what we had onchip) was 100 * 100 slower at 11.4 milliSeconds. As result, the design team finally was persuaded to both (1) move the ItsHot sensor much closer, and (2) redesign the power output devices to ensure current uniformity even when hot.
Why are there not books, or chapters in books, on such thermal-survival design? I think its because sometimes we engineers have to extend our personal understanding beyond what we've been taught. And if such understandings lead to more profitable products (perhaps they build a better reputation among the customer base), then we can say "This is a proprietary understanding. Do not publish about it."
This is why "world class design teams" will "lose the magic touch". There are many traps between concept of system-on-silicon and success. If the team, in early products, should get lucky and avoid a few of the traps, but in later versions stumble into such traps, chances are the revenues collapse and the team is dispersed, because crucial phenomena were not identified and methods developed to manage the RISKS.
  • \$\begingroup\$ I see. So usually the thermal protection circuit is placed too far away in the IC to protect against short circuits... is the protection circuitry some sort of diode like you mentioned? Could you point to any resources where I can read more about that ? \$\endgroup\$
    – VanGo
    Commented May 8, 2020 at 18:30
