Devices: STM32F4
The SD is working and the data is saving on the SD, but the problem is that the integers are displayed as symbols in this SD. So I think that the problem is that the function I used needs char, and the data is int, so is there any way to convert int into char for 2 digits?
Code:
while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
        HAL_RTC_GetTime(&hrtc,&sTime,RTC_FORMAT_BIN);
        HAL_RTC_GetDate(&hrtc, &sDate, RTC_FORMAT_BIN);
char month = sDate.Month;
        /* Mount SD Card */
  if(f_mount(&fs, "", 0) != FR_OK)
Error_Handler();
  /* Open file to write */
  if(f_open(&fil, "second.txt", FA_OPEN_ALWAYS | FA_READ | FA_WRITE) != FR_OK)
Error_Handler();
  /* Check free space */
  if(f_getfree("", &fre_clust, &pfs) != FR_OK)
Error_Handler();
  total = (uint32_t)((pfs->n_fatent - 2) * pfs->csize * 0.5);
  free1 = (uint32_t)(fre_clust * pfs->csize * 0.5);
  /* Free space is less than 1kb */
  if(free1 < 1)
Error_Handler();
  /* Writing text */
    if(freq <=120000 && freq>= 80000){
          f_puts(&month, &fil);
  f_puts("\n", &fil);
  /* Close file */
  if(f_close(&fil) != FR_OK)
Error_Handler();
  /* Open file to read */
  if(f_open(&fil, "second.txt", FA_READ) != FR_OK)
Error_Handler();
  while(f_gets(buffer, sizeof(buffer), &fil))
    //printf("%s", buffer);
  /* Close file */
Error_Handler();
  /* Unmount SDCARD */
  if(f_mount(NULL, "", 1) != FR_OK)
Error_Handler();
  /* USER CODE END 3 */
You are writing the variable data directly to the file. You need to convert the data into a printable text string of ascii symbols and write the string to the file. You can use sprintf to do it, almost like when printing to serial port with printf.
