We have a 3 phase electronic motor with a 'useful' power 4kW. Its efficiency is 80% Currents on the lines are equal in all three phases, and they are lagging behind the voltages by 30 degree. We need to make a power factor correction in such a way, that the phase difference between the current and voltages becomes less than 10 degree.
And I am totally lost.
Is the efficiency the power factor? Do we have to do anything by the fact that it is lagging? (Other than it shows that we need to use a capacitor for the correction?) Why less then 10 degree and not zero?
Tried looking up videos and googling, but that only made me more confused :/
ps: Voltage is 230 Volt and 50 Hz. If the example needs this information.
    \$\begingroup\$ Hint: if it's a motor, it's a resistive-inductive load. The capacitive load would be the opposite of that. \$\endgroup\$ May 8, 2020 at 18:11
No. The efficiency tells you how much of the electrical power coming into the motor is converted to "useful" power, mechanical power transferred to the load.
No.
A better question would be why not "less than X degrees but not less than 10 degrees?" If too much correction is done, an induction motor can become self excited and not coast to a stop promptly when it is shut off. Motor manufacturers often specify a maximum amount of correction. Correcting to zero degrees is never a good idea. Correcting to 10 degrees pf = 0.98 seems a bit much.
I assume this is an induction motor, not an "electronic motor." An electronically controlled motor should not have power factor correction.
I read this observation as the line current lagging the line voltage by 30 degrees.
Take a look at a 3 phase phasor diagram: -
And concentrate on one of the line voltages, namely \$V_{RY}\$ - this voltage naturally leads the local phase voltage \$V_{R}\$ by 30 degrees. It's the same for the other line voltages - each line voltage leads its respective phase voltage naturally by 30 degrees.
Given that a resistive balanced load would draw a current in phase with \$V_{R}\$, I have to conclude that your "3 phase electronic motor" is running close to unity power factor.
I have serious doubts about that so, get someone in who can be trusted to make proper measurements and make a local recommendation.
