In the circuit above I've been asked to calculate the average power absorbed by the 10 Ω resistor. I managed to calculate a value for \$V_0=40\sqrt2\,\angle{-25}\$.
But I'm not sure if this is peak or rms voltage. I've spoken to some people and they say that the rms value is simply \$40\sqrt2\$, which doesn't really make sense to me, and I've spoken to other people who say to follow the \$\frac{V_p}{\sqrt2}\$ formula, which makes a lot more sense to me.
I'm not really sure who to believe, so I've come here seeking help.
  • \$\begingroup\$ You should just ask the instructor for clarification. \$\endgroup\$ May 9, 2020 at 13:50
    \$\begingroup\$ I love how the title of your question and your username form a pun. \$\endgroup\$ May 9, 2020 at 20:51
  • \$\begingroup\$ That was a mean thing to say @MarcusMüller lol \$\endgroup\$
    May 10, 2020 at 9:00
Noting this: -
When your circuit says this (my words in red): -
In the absence of any other information, AC voltages are always presumed to be RMS.
See this Wiki reference: -
the magnitudes of the voltage and current phasors V and I are the RMS values of the voltage and current, respectively).
And...
Well, unless you have decided to convert to sinusoidal peak values, you will have calculated a value based on an input of 8 volts RMS.
RMS of a sinusoid is the square root of 2 smaller than the peak amplitude (\$\frac{V_m}{\sqrt2}\$ ).This link should help.
In power system analysis texts we almost always use rms magnitudes. e.g. A current of 5@45 degrees amps is 5A rms or 7.07A peak.
