What should I put in ''Three-Phase Programmable Voltage Source'' block ?enter image description here
  • \$\begingroup\$ What are you trying to accomplish? Your goal of modeling here. \$\endgroup\$ – relayman357 May 9 '20 at 20:43
  • \$\begingroup\$ can't tell you what to put in a parameter field without knowing what the thing you're parameterizing is supposed to do. You will need to describe extensively what the objective of your model is, and what you have understood and considered so far. \$\endgroup\$ – Marcus Müller May 9 '20 at 20:47
  • \$\begingroup\$ not modeling. The question is to find Isc @ different values of Vdf. Actually, I found that Isc inc. while Vdf is increasing ,but they are not realistic. @relayman357 \$\endgroup\$ – uob May 9 '20 at 21:28
  • \$\begingroup\$ the objective is to find Isc at different values of Vdf. Actually, I found that Isc inc. while Vdf is increasing ,but they are not realistic. @MarcusMüller \$\endgroup\$ – uob May 9 '20 at 21:39
  • \$\begingroup\$ OK, it looks to me like that voltage source just represents infinite bus to which your generator is connected. \$\endgroup\$ – relayman357 May 9 '20 at 21:39
I would start out with a voltage that matches your machine. Vars flow from higher voltage to lower, so as you change this system voltage you should see corresponding change in var flow. Power flow is controlled predominately by phase angle. So, as you play with that you should see changes in power flow. See this link for more clues.
The link you gave in your comments above seems very explicit in detail. Including giving the values you are talking about.
To apply a short circuit you need your voltage source to go to zero (on whatever phases you want to fault, or all 3 if three-phase fault).
