I have a circuit where the only current I can get to supply my battery is the one that I can get from a relay connected to Vcc.
When it is not pulled to GND I can get current without activating it up to around 12mA.
Is there some way to get more current without activate the relay?
I've done some tests connecting this to LC filter and a buck converter and I think I'm getting more current, but this circuit seems too sensible to changes (If I want to prevent the relay activation).
Edit:
I need to power this circuit in a place where there is no power outlet or other power supply, so the only place where I can get power is from the relay (But I can't access to the wire connected to VCC, only the wire that goes to GND) . This is the relay from the intercom of a entry door building (when you press the switch you power this relay so the door opens. I tried this circuit in several places and there are buildings with AC powering this relay or more voltage so the current I can draw is enough, but other places have to low current capability (only 15mA before relay activates). The max current through the relay is 70mA when SW1 is pressed.
Edit2 (reply to Pipe and more info): Yes, it is Energy Harvesting situation, but I could not found the best way to solve it to works in any different scenario. I've tried supercapacitor approach, charger connected directly to the harvest source, and now I get the best results with buck+charger
Edit3: My circuit draws an average 48mA (connected to Vbat) and the current that I get now from the relay is 10mA at 9V-7V, but the efficiency of the buck and charger is not too high at low currents so I'm charging to 10mA at Vbat (whith 30mA or more the total efficiency is more than 60%), the battery acts like UPS and helps to handle current peaks
Edit4: I've also checked some MPPT (Maximum Power Point Tracker) way to approach this, but I did not see something valid
    \$\begingroup\$ A schematic is better than words. You can add one in using the CircuitLab button on the editor toolbar. Double-click a component to edit its properties. 'R' = rotate, 'H' = horizontal flip. 'V' = vertical flip. Note that when you use the CircuitLab button on the editor toolbar and "Save and Insert" on the editor an editable schematic is saved in your post. That makes it easy for us to copy and edit in our answers. You don't need a CircuitLab account, no screengrabs, no image uploads, no background grid. \$\endgroup\$
    – Transistor
    Commented May 9, 2020 at 20:45
    \$\begingroup\$ Essentially you're looking at an energy harvesting situation here, which may help figuring out what you need to do. \$\endgroup\$
    – pipe
    Commented May 9, 2020 at 22:07
    \$\begingroup\$ The schematic is a huge help. You haven't told us what your power requirements are - average and peak and peak duration, if they're relevant. \$\endgroup\$
    – Transistor
    Commented May 9, 2020 at 22:11
    \$\begingroup\$ The inductance of the relay will change when the armature is closed. See my answer to electronics.stackexchange.com/a/487353/73158. Could you sense that? It might be easier to stop drawing current for a second every 20 s or so. \$\endgroup\$
    – Transistor
    Commented May 9, 2020 at 22:55
    \$\begingroup\$ hm, how are chances you can charge a supercapacitor really quickly when the button is pressed and live off that? \$\endgroup\$ Commented May 9, 2020 at 23:02
You can try to very slowly ramp up the current to slightly increase the 12mA, but no matter what you're doing:
Your relay is an electromagnet, and the force an electromagnet can exert is directly proportional to the current through it.
So, there's no reliable way to drawing significant current through your relay's coil without risking to trigger it – after all, any relay is designed to reliably trigger.
I sense a very strong XY Problem here: you're trying to solve another technical challenge by trying to pull current through your relay. That's almost certainly the wrong approach, but we can't help you find the right approach without you telling us what you're actually trying to solve. So, I recommend editing your question and telling us exactly what you're trying to solve, and why the relay coil has to be in line in your application.
    \$\begingroup\$ @danirebollo: Don't ask another question. Fix the one you've asked at the top of the page! \$\endgroup\$
    – Transistor
    Commented May 9, 2020 at 20:41
    \$\begingroup\$ @Transistor is right, if this but takes a bit of changing your question, please just change your question. I was assuming you're having a drastically different problem that's larger, and really warrants a new question, but probably: you aren't, and editing your question would be the right thing to do. \$\endgroup\$ Commented May 9, 2020 at 20:42
