I'm thinking of using the DW01 IC to make a simple non rechargeable battery protection (over current, short circuit, over discharge). The sample schematic requires two Power fets, one to control discharge and the other to control charge.
My problem is that I don't need the charge control, charging will cause my battery to explode. What I actually want is for the FET to be closed if a charger is present (reverse polarity protection)... is there a way to do this with the DW01 by changing the FET or some other tweak?
Looking forward to seeing what's possible!
