I keep on getting an error of multiple source. Here is my code for the testbench I am making.
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity comparator_testbench is end comparator_testbench;
architecture behavior of comparator_testbench is --define the max delay for the DUT constant MAX_DELAY : time := 20 ns;
-- declare a constant to hold an array of input values type input_value_array is array (0 to 9) of STD_LOGIC_VECTOR(7 downto 0); constant in1_sig_values : input_value_array := ("00000000","00000001","00010010","00000100","00001000", "00010000","00100000","01000000","10000000","00000011"); --------------------------------------------------- constant in2_sig_values : input_value_array := ("00010000","00100000","00010010","10000000","00000011", "00000000","00000001","00000010","00000100","00001000"); --------------------------------------------------- constant in3_sig_values : input_value_array := ("00010000","00000001","0000001","00000001","01000000", "00000010","10000000","00000011","00000100","00001000"); --------------------------------------------------- constant in4_sig_values : input_value_array := ("00000010","00110101","0000001","00000001","01000000", "00000010","10000000","00000011","00000100","00001000");
-- define signals that connect to DUT signal input_1_sig : STD_LOGIC_VECTOR(7 downto 0); signal input_2_sig : STD_LOGIC_VECTOR(7 downto 0); signal input_3_sig : STD_LOGIC_VECTOR(7 downto 0); signal input_4_sig : STD_LOGIC_VECTOR(7 downto 0); signal min_index_sig_2: integer; signal max_index_sig_2: integer;
begin
-- this is the process that will generate the inputs
stimulus : process
begin
for i in 0 to 9 loop
input_1_sig <= in1_sig_values(i);
input_2_sig <= in2_sig_values(i);
input_3_sig <= in3_sig_values(i);
input_4_sig <= in4_sig_values(i);
min_index_sig_2 <= i;
max_index_sig_2 <= i;
wait for MAX_DELAY; -- do nothing right now
end loop;
wait;
end process stimulus;
-- this is the component instantiation for the
-- DUT - the device we are testing
DUT : entity work.comparator(behavioral)
port map(input_1 => input_1_sig, input_2=>input_2_sig,
input_3 => input_3_sig, input_4=>input_4_sig,
min_index => min_index_sig_2, max_index => max_index_sig_2 );
end behavior;
Here is the code for the comparator file:
entity comparator is
Port (input_1 : in STD_LOGIC_VECTOR (7 downto 0); -- Input stream input_2 : in STD_LOGIC_VECTOR (7 downto 0); -- Input stream input_3 : in STD_LOGIC_VECTOR (7 downto 0); -- Input stream input_4 : in STD_LOGIC_VECTOR (7 downto 0); -- Input stream min_index : out integer; -- Index max_index : out integer; MAX_OUT : out STD_LOGIC_VECTOR (7 downto 0); MIN_OUT : out STD_LOGIC_VECTOR (7 downto 0));-- The minimum of the stream
end comparator;
architecture Behavioral of comparator is signal min : std_logic_vector(7 downto 0):="11111111"; signal max : std_logic_vector(7 downto 0):="00000000"; signal min_index_sig : integer; signal max_index_sig : integer; begin
find_min : process
begin
if ((input_1 <= input_2) and (input_1 <= input_3) and(input_1 <= input_4)) then
min <= input_1;
min_index_sig <= min_index_sig;
elsif ((input_2 <= input_1)and(input_2<=input_3)and(input_2<=input_4)) then
min <= input_2;
elsif ((input_3 <= input_1)and(input_3<=input_2)and(input_3<=input_4)) then
min <= input_3;
elsif ((input_4 <= input_1)and(input_4<=input_3)and(input_4<=input_2)) then
min <= input_4;
else
min <=min;
end if;
wait;
end process find_min;
MIN_OUT <= min;
min_index<=min_index_sig;
find_max : process
begin
--if ( input > max ) then
--max <= input;
--max_index_sig <= max_index_sig;
--else
--max <= max;
--end if;
if ((input_1 >= input_2)and(input_1>=input_3)and(input_1>=input_4)) then
max <= input_1;
elsif ((input_2 >= input_1)and(input_2>=input_3)and(input_2>=input_4)) then
max <= input_2;
elsif ((input_3 >= input_1)and(input_3>=input_2)and(input_3>=input_4)) then
max <= input_3;
elsif ((input_4 >= input_1)and(input_4>=input_3)and(input_4>=input_2)) then
max <= input_4;
--include max index sig in testbench
else
max <=max;
end if;
wait;
end process find_max;
MAX_OUT <= max;
max_index<=max_index_sig;
end Behavioral;
