So I used a comparator to compare a sawtooth signal and a reference voltage and I obtained the PWM signal at the output of the comparator. My question is what formula can I use to vary the duty cycle of the PWM signal as I like? This is the part of the circuit which adjust the duty cycle of my PWM signal.
I was thinking to use a potentiometer between 2 resistors and to vary the duty cycle by varying the values of the resistances. +/- Vps=+/-15V
Thanks in advance!
  • \$\begingroup\$ You ask for a formula but then you say you're thinking to use a potentiometer? At any rate, if this is a dynamic case, then simply remove the pot and use the other input as the reference. See this, for example. \$\endgroup\$ Commented May 10, 2020 at 21:02
  • \$\begingroup\$ Is mandatory to use a potentiometer, so that when i set it on '0' the duty cycle is 50% and when i set it on '1' the duty cycle is 70%. \$\endgroup\$ Commented May 10, 2020 at 21:07
  • \$\begingroup\$ What is the range of your sawtooth? \$\endgroup\$
    – K H
    Commented May 10, 2020 at 21:20
  • \$\begingroup\$ Vmin=-11.75V and Vmax= 11.25V \$\endgroup\$ Commented May 10, 2020 at 21:22
  • Work out what your sawtooth minimum voltage is. Let's call that Vmin.
  • Work out what your sawtooth maximum voltage is. Let's call that Vmax.
  • Now work out the voltage for 50% (half-way) between Vmin and Vmax. Let's call that V50.
  • Then work out the voltage for 70% between Vmin and Vmax. Let's call that V70.
You've chosen a 1 kΩ pot so now work out the current through that from \$ I = \frac {V_{max} - V_{min} }{1k} \$.
Can you work out what value you require for R5 and R6 now so that the ends of the pot are held at the required voltages?
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. \$\endgroup\$
    – Voltage Spike
    Commented Jun 12, 2020 at 16:39
