I am trying to connect to an e-bike controller to reprogram it, and have to find the female counterpart to this connector for this purpose. Ideally, I want to find the part that will plug into this. I've spent a couple of hours going through lists of connectors, but no luck so far.
Here is a photo showing the cable connector I have:
- 6 pins
- external diameter ~8mm
- internal diameter ~6mm
- as shown on the photo, there is a flat part on the top side of the photo
- the connection is made by pushing the other part in, no screwing or baionets
- given that it is on an outdoor bicycle kit, I'd think it has a reasonable water-tightness rating.
- it says "JULET" on the side of the connector (it's hard to see this on the photo)
- the casing is somewhat flexible plastic material
Any tips would be great!
