I'm building an AC-charging device for electric vehicles (the standard calls it an "ICCPD" or an "In Cable Control and Protective Device") and I'm facing some EMC issues due to the PWM Signal on the CP-wire.
Background:
The charging device is connected to the vehicle via the type-2 connector. The cable to the EV looks like this and is approx. 5-10m long: enter image description here
The CP wire is used for the communication between the vehicle and the ICCPD. Basically it carries a PWM signal and the duty cycle indicates the maximum charging current. The frequency, amplitude and rise-time is defined in the standard.
  • f=1kHz
  • positive amplitude = 6/9/12V (relative to PE)
  • negative amplitude = -12V (relative to PE)
  • rise/fall time = <2us
Problem description:
The following figure shows the conduced emissions with PWM signal ON (turquoise) and without PWM signal...const +12V (blue) measured on the neutral line. Cable length was 9m. Measured with Rohde&Schwarz Precompliance test equipment (HMS-X and HM6050-2).
Question:
Is there any way to reduce the conducted emissions due to the CP-Signal?
Update 1:
Reducing the cable length and/or shielding the CP-wire is not possible.
Update 2:
According to my understanding the equivalent schematic looks like this!? And the Problem is the parasitic capacitance between CP and N (Neutral), which is approx. 60pF/m based on the dimensions. enter image description here
Update 3:
conduced emissions according to Andy's suggestion/ thought experiment:
  • Turquoise line: PWM Signal on CP wire inside the cable
  • Blue Line: PWM signal connected to a separated wire (no PWM signal on CP wire in the cable)
  • \$\begingroup\$ Can you add source termination? Or something to reduce the rise/fall time? \$\endgroup\$
    – Aaron
    May 11, 2020 at 16:26
  • \$\begingroup\$ Is the positive amplitude, 6 or 9 or 12, or does it need to be capable of doing all of them? Can you only choose 6v? \$\endgroup\$
    – Aaron
    May 11, 2020 at 16:27
  • \$\begingroup\$ The maximum rise/fall time is defined in the standard as 2us. Therefore I can't solw it down any more. (As far as I know some vehicles deny charging if the rise time is too slow...Tesla Model 3 for example!?) \$\endgroup\$ May 11, 2020 at 16:35
  • \$\begingroup\$ Basically it's only relevant for 6V (=charging mode...relais closed). For 9V and 12V the relais for L1/L2/L3 and N are open, which leads to good EMC results. \$\endgroup\$ May 11, 2020 at 16:38
  • \$\begingroup\$ Thought experiment: If the charging signal is applied differently (bypassing the cable entirely so that it can be ruled out as a direct contributor) then what does the conducted emission graph look like? What I'm suspicious about is that THE CE fail is actually from PWM current flow down the cable and the voltage pulsing is immaterial i.e. it's the charging current that is the culprit. \$\endgroup\$
    May 11, 2020 at 16:41
The first null, of the second/green plot, is at 1.2MHz.
From what I've seen on Spectrum Analyzers (and in Fourier modeling), the first null is at 1/Trise.
So yes ----- If you can slow down the edge, give that a try.
How you chose to DAMPEN the filter may be key. Experiment with parallel or series resistors with the inductor.
EDIT:
Install a "L" or "T" or "PI" filter, with cutoff at 1MHz (about 0.5uS Trise).
The idea is to weaken the correlation of the "fast edge" with the FFT algorithm inside the R&S boxes.
By converting a perfect RAMP edge into an "ESS" edge, having sort attack and soft delay edges before and after the "rise time", the correlation will be reduced.
  • \$\begingroup\$ Unfortunately I can't reduce the slew rate anymore. The maximum rise/fall time is defined in the standard as 2us. (As far as I know some vehicles deny charging if the rise time is too slow...Tesla Model 3 for example!?) \$\endgroup\$ May 11, 2020 at 16:40
  • \$\begingroup\$ What do you mean with CLOCK and DATA? There's just one communication wire...the "control pilot" signal or short "CP" which carries a PWM signal \$\endgroup\$ May 11, 2020 at 16:43
