In transformers, when the voltage is powered up, the current is proportionally powered down.
In the x-ray tube’s transformer, this also happens.
However, the current of an x-ray tube is not the powered down current from its transformer. It is the current that results from electrons produced due to thermionic emission at the cathode (the tube current).
Supposing there is an amount of power (let us call it x) that if fed into the thermionic emission circuit of the x-ray tube would enable the tube current to rise to a value just above the powered down current.
Let us label the power fed into the x-ray tube’s transformer as y.
Let us refer to the electrical equivalent of heat produced at the anode per second as a.
We shall refer to the electrical equivalent of x-rays produced per second as b.
x and y are the only power inputs. a and b the only outputs.
If x added to y is less than a added to b, then the x-ray tube would be producing more power than it was given.
I have considered that the maximum temperature we can allow the Tungsten cathode to reach is that just below its melting point.
However, I was wondering whether this entire assertion could be pitched against the goal of producing cleaner more affordable energy in the world.
Checkout this document for more details related to my question: https://drive.google.com/file/d/1OoLYuZUxcAMxKYV8-CjcVu_hns_HZnJJ/view?usp=sharing
