I am trying to create a parameterized covergroup in my testbench as follows:
covergroup CG (input int id);
    cp1 : coverpoint tb.gen_block_mem[id].var_x[3:0];
endgroup : CG
CG CG_0  = new(0);
CG CG_1  = new(1);
This fails in elaboration as the id variable is not a constant. Is there a SystemVerilog workaround for this so that I can instantiate covergroups just like parameterized modules?
Assuming tb.gen_block_mem is a generate block, you'll have to put the covergroup in another generate block
for(genvar id=0;id<MY_P;id++) begin : cg_block
 covergroup CG;
 endgroup : CG
 CG cg  = new;
end : cg_block
