I'm using the following logic in a design:
module flipflip (
   input wire d,
   input wire clk,
   input wire en,
   output reg q
always @(posedge clk) begin
   if (en) begin
      q <= d;
   end
end
endmodule
However, the behavior I actually want is
module flipflip (
   input wire d,
   input wire clk,
   input wire en,
   output reg q
   if (en) begin
      q <= d;
   end else begin
      q <= q;
   end
end
endmodule
That is, if the en flag isn't asserted the flip flop should just keep it's old value. Are these necessarily equivalent? I.e. do I have to code the 2nd, or can I get away with coding the 1st?
I wasn't able to track this down in the Verilog 2005 standard. Where is this covered?
Yes, they are equivalent. IEEE Std 1364-2005, section 6.2 Procedural assignments states:
...procedural assignments put values in variables. The assignment does not have duration; instead, the variable holds the value of the assignment until the next procedural assignment to that variable.
You do not need to use the 2nd code example.
The IEEE Std1800-2017 is the current LRM. Section 6.5 Nets and variables says:
Variables can be written by one or more procedural statements, including procedural continuous assignments. The last write determines the value.
So they are equivalent. But there is also a uniform synthesis coding guide that says something like
A storage device gets inferred whenever you write to a variable in some branches of an always block, but not all, and that variable is read without being written to, or referenced outside that block.
Your two examples are functionally equivalent - the first one is common practice
  • \$\begingroup\$ Great, I thought so, I just wanted to be sure. Any chance you know where this is discussed in the standard? \$\endgroup\$
    – MattHusz
    May 12, 2020 at 22:57
    \$\begingroup\$ @MattHusz: I added an Answer. \$\endgroup\$
    – toolic
    May 13, 2020 at 0:16
