This is my first question here so I'll try to make it as clear as possible.
I've bought a T.V53.03 control board to use with an old laptop display I have at my home. After searching for the display model I found it to be an LTN133AT09 display, which uses a 1Ch 6bit LVDS cable. The problem I have is that the control board ships with a 2Ch 6 bit LVDS cable, and I was wondering if it will work out of the box with the display.
In summary, my two questions are:
  • Will the LVDS cable work out of the box with my LCD?
  • Can I cut out some wires of the LVDS 2Ch cable to make it compatible? Or should I buy a 1Ch cable?
Thanks in advance for the answers!
It's not about just cable, the board must be configured to send on signle link. If that is not possible then those two are just not compatible.
  • \$\begingroup\$ Hi, thanks for the response, I looked up the board spec sheet and it supports both 1Ch and 2Ch 6/8 bit. Considering this, could it work if I removed the even wires from the 2Ch LVDS cable? \$\endgroup\$ May 13 '20 at 15:33
  • \$\begingroup\$ You can leave them unconnected, but you have to check if the single channel is sent over odd or even pins. And otherwise check that each pin on the display is connected to correct pin on the control board. You must not simply expect the pinouts to match out of the box. \$\endgroup\$
    – Justme
    May 13 '20 at 15:44
For high-speed links like LVDS it's a good idea to terminate unused pairs at both ends to minimize losses due to crosstalk. Apart from that only using 1...M pairs of a N-pair cable is fine.
