When looking for oscilloscopes, you often see the following specs:
- bandwidth [in Hz]
- sampling rate [in Samples/s]
- capture rate [in waveforms/s]
- record length [in pts/channel]
My question is: How are these specifications related?
Take for example the following comparison table from the company Siglent:
All these scopes have a sampling rate of 1GSamples/s, meaning they can take 1 billion measurements every second. From the Nyquist-Shannon Theorem these scopes should all be capable of accurately measuring frequencies up to 500MHz. But their bandwidth only allows for at most 200MHz, and only 100MHz for the scope in the centre row. How is this reconcilable?
