I would like to control a relay using an esp8266 module sending the signal. However, I want to also have an optional push button in case my internet is down.
Is this possible? If yes, how can I do this? Eg. Schematic etc.
This is the relay i'm using:
Here is the relay I'm using
This is my attempt at a block diagram: My attempt at a block diagram
  • \$\begingroup\$ Why not put an on-off switch in parallel with the relay contact? \$\endgroup\$
    – Transistor
    Commented May 13, 2020 at 21:27
  • \$\begingroup\$ Is there somewhere online I can read into it? I'm confused about how the schematic would look. \$\endgroup\$
    – Yousuf
    Commented May 13, 2020 at 21:34
  • \$\begingroup\$ @Yousuf Does it have to be a push button (push on, push off) or would a switch like a light switch be good? \$\endgroup\$ Commented May 13, 2020 at 21:36
  • \$\begingroup\$ Light switch would be just fine. \$\endgroup\$
    – Yousuf
    Commented May 13, 2020 at 21:37
    \$\begingroup\$ @Yousuf OK, please edit your question to add a block diagram of the circuit you have at the moment so that we can show you what to add and/or change. \$\endgroup\$ Commented May 13, 2020 at 21:38
I found this schema on the following website:
https://www.hackster.io/yazsansh/affordable-alexa-enabled-iot-f7d638
The poster claimed that it would allow for activation by ESP as well as manually. So I will attempt to duplicate the schema with some minor adjustments (his relay has the Common at the bottom while mine is in the center):
