I came across this on a schematic and I'm not 100% sure what its function is.
On the BOM it has a resistor package, denoted like this FB1, FB2 FB_0 RES 1206 (755-4709) RS CODE (I tried looking this up on RS and got nothing.)
Just from FB I would guess it's a ferrite bead.
unknown symbol
It's a surface-mount ferrite bead in 1206 package. Other parameters would include current rating and impedance (usually specified in ohms at 100MHz).
  • \$\begingroup\$ ah cool, is there anything you can pull from that RS code to help identify what parameters those 2 in particular have. \$\endgroup\$ Commented May 14, 2020 at 0:21
  • \$\begingroup\$ They don't seem to have any relationship to the manufacturer's part numbers. You could try calling them for a suggested substitute part. If not, probably a 1K @ 100MHz 1206 part would do, like Murata BLM31KN102SN1L. \$\endgroup\$ Commented May 14, 2020 at 0:32
  • \$\begingroup\$ Yeah, going off what ST usually uses i would guess something along the lines of Murata. I've sent them an email asking what specs to go for so we'l see what happens when they come back to me on that. appreciate the follow up mate. \$\endgroup\$ Commented May 14, 2020 at 0:45
  • \$\begingroup\$ You can ask RS too. They should have records of what they used to sell. \$\endgroup\$ Commented May 14, 2020 at 2:16
    \$\begingroup\$ I did, they told me that they have deleted the records of it. \$\endgroup\$ Commented May 14, 2020 at 4:23
Looking deeper into google i found a few expired pages off RS that refer to the product https://www.digikey.com/product-detail/en/taiyo-yuden/LB3218T1R5M/587-3082-1-ND/2763507
