Is it possible to adjust the stroke range of LACT4-12V-20 when using jrk 21v3 to control it. The LACT4-12V-20 does not have feedback, so it is not possition controlled. I guess if this is possible then it should be done in the jrk settings maybe.
This is the documentation for jrk 21v3 motor controller
And here are some resources for the LACT4-12V-20 motor
LACT4-12V-20 motor:
LACT4-12V-20 motor
jrk 21v3 motor controller:
  • \$\begingroup\$ If you want positional control then you'll need some form of feedback. If all you want is to set the stroke range you can do that by fitting limit switches in the appropriate positions. \$\endgroup\$ – user16324 May 15 '20 at 9:52
