I have been scrolling like a zombie through Digikey, Farnell and Molex websites to identify the reference of this fairly common looking 5 pin connector of a board I am reverse engineering, but couldn't find it yet.
I would greatly appreciate if someone could shorten my sufferings.
Male connector view 1
Male connector view 2
Female PCB connector
Best regards
    \$\begingroup\$ It would probably help to edit your question and add outside dimensions and pitch. \$\endgroup\$
    – Jack B
    Commented May 15, 2020 at 19:54
  • \$\begingroup\$ Thanks Jack B, I took a bet that this was a sufficiently mainstream connector so that an experienced EE engineer would recognized it, and it worked. If I need to ask a similar question again, I will include connector metrics. \$\endgroup\$
    – nicolaje
    Commented May 15, 2020 at 20:38
That is almost certainly a JST XH series. XHP-5 to be precise.
Digi-Key link.
These are quite common and can be found in many places. Just search for "JST XHP-5".
BTW, here are the correct terminals to use: Digi-Key link
  • \$\begingroup\$ Thanks a lot for making me able to not spend hours on this topic where I am absolutely not qualified or experienced. \$\endgroup\$
    – nicolaje
    Commented May 15, 2020 at 20:36
Probably one of these:
Manufacturer Part Number: S5B-XH-A(LF)(SN)
Description: CONN HEADER R/A 5POS 2.5MM
Source: https://www.digikey.com/product-detail/en/jst-sales-america-inc/S5B-XH-A-LF-SN/455-2242-ND/1651040
