I want my CPLD (a MAX II CPLD, EPM240, see datasheet) to accept an S/PDIF input using an optical receiver with TTL-compatible output.
I tested the receiver alone: when giving proper power and optical connection to an emitter, its output pin shows a nice waveform on the oscilloscope.
But when connecting it to a pin of the CPLD configured as input (pin 44, 3.3-V LVTTL, default) I stop seeing the waveform; instead the signal seems stuck to ~3V. Of course the CPLD receives no data.
Suspecting that the CPLD pin was accidentally configured as an output, I disconnected the receiver and connected the pin to a 10kΩ pull-down resistor. I'd expect almost 3V if it were an output and almost zero if it were an input, instead I measure a voltage of 1.6V which is something in the middle.
So why is the CPLD behaving so weirdly with a digital input, almost behaving like it was configured as output?
Found out that pin 44 was faulty, probably burnt by earlier experiments. Remapping to another pin like pin 52 solved the issue and the signal can now be read.
