I'm working on a design that uses two separate buck regulators to generate a positive and negative voltage, and I'm trying to implement current limiting with a current sensor. However, I am running into issues with the way the sense resistor is integrated into the feedback loop as shown in my block diagram below:
With the way the regulators are set up, the current sense resistors have to be included in the appropriate feedback loops in order to maintain the correct output voltage. Otherwise, the regulator won't take into account the voltage drop, and the output voltages will be less than what is expected.
The issue is with the way the two regulators are configured. When you add the sense resistor to the negative voltage circuit, it seems to create a different 'return node' for the negative voltage. If it wasn't there, both regulators can be tied to the ground node at their returns. What other methods of current sensing can be used for the negative voltage circuit such that the appropriate returns can be tied together?
EDIT: As Hacktastical said, there is a way to have a buck regulator output a negative voltage. I based the reference circuit off of an app note from TI:
