Is there a safe or better way of using an AAA battery in place of an AA battery in small electronic devices/ sensors, when in bind like pandemic?
For possible use in small electronic devices without moving parts; remotes (IR, Bluetooth, RF etc) or sensors (temperature/ humidity type sensors) etc.
PS: Not using a motor, so this question title though similar, is not related.
There are plenty of sites/ you tube videos that talk about using an aluminum foil as a connector.
Given how it's a crumpled sheet and not a SOLID type connector, I would think it is subject to weird electrical properties (and hence not recommended), as compared to a SOLID connector.
Only if devices has some kind of "spring loaded" connector which allowed them to use "either" AA or AAA.
:) Wishful
(Although FireStick 4K remote connectors are nice cylinders (spring loaded) & not just thin coiled dpring wires (unless something of that type might help).
Is there a safe, decent, SHAPE/ OBJECT / MATERIAL that can be easily be used in place without the flaws with such hacks with foil?
Update:
So, the solution would revolved around:
- Conductive item (preferably solid) to fill in for the Length & not dodge / wiggle around
- Non conductive surround/ wrap around stuff to fill in for the Width an prevent dodge / wiggle around
Given the uncertain times ahead of us (this could have impact for 6-12 months on all kinds of supply), I've found both answers useful - and better than Foil ball. Open to more.
PS: We are in an asian city locality surrounded by Hot Zones - even medicine & food are hard to procure. A friends building, one case was detected - police lock down for 2 weeks now.
Its not the time to be close minded or nit-picky given that both are decent solutions, if one ends up with AAA's at home (due large no of devices) and needs AA in a pinch.
- One "adapter-kit" is something to keep, get if one is able to, for longer term, a must have that I was unaware of, given that AAA batteries & devices are common & around
- (kinda like have all kids of screwdriver heads even if you rarely use a certain type),
- Other - DIY w object or similar from home/ hardware (a bolt in linked SE answer)
- Would appreciate more such "DIY" ideas with the decent "electrical properties", better than a foil ball.
