I have this digital logic circuit homework and I've been trying to solve it for a day and in the end I got a wrong answer. Here is the question:
Create a majority gate using only NOR gates, with 4 inputs a,b,c,d. Which means the output will be 1 if the majority of inputs are 1.
I draw the truth table and Karnaugh map, but they weren't helpful really.
The logical expression will be: a'bcd + ab'cd + abc'd + abcd' + abcd.
If we simplify it we will get: bcd + acd + abd + abc.
I tried to simplify it to a NAND form and I got a very long expression which was not true(I checked it with Proteus).
Can anyone help me please?
    \$\begingroup\$ Can you show your work (how did you reach this expression you're talking about and your NAND form)? Also, a "majority gate" with 4 inputs seems strange: what is its output if there are two 0s and two 1s? \$\endgroup\$
    – Renan
    May 17, 2020 at 20:31
  • \$\begingroup\$ I reached to this expression using truth table, and then I complemented the whole expression twice( I mean like a") and simplified it in some steps. \$\endgroup\$
    – Artemis
    May 17, 2020 at 20:46
  • \$\begingroup\$ If there are two 0s and two 1s, the output will be zero I think. I saw the truth table on the internet (images.app.goo.gl/MijAcKLH9gd312jN8). \$\endgroup\$
    – Artemis
    May 17, 2020 at 20:49
You can implement any logic circuit using only NANDs, it doesn't mean you will use a single NAND. Try writing down how to implement the following logic gates using NANDs
  • AND
  • OR
  • NOT
With those you can definitely implement the function you have, but simplifying it will require either manipulating the boolean expression bcd + acd + abd + abc to write it with NANDs or using Karnaugh maps (but it is a bit different than the one for AND/OR simplification).
