How can I read Thevenin voltage from such circuit in LTSPICE? I know how to get Thevenin resistance in LTSPICE. I calculated manually values that I expect to get from LTSPICE and indeed Thevenin resistance is almost the same.
  • \$\begingroup\$ Differential probing? L-Click, hold, drag to another node, release L-Click. \$\endgroup\$ – a concerned citizen May 18 at 11:00
  • \$\begingroup\$ Yep that did the trick. Thank you so much \$\endgroup\$ – xarix May 18 at 11:11
