(Context: I don't have a background in e.e., but getting better at basic bench work.) I'm repairing/recapping an early 70s German integrated stereo. The power amp output section has four large heatsinks for its transistors, two each corresponding to the left and right stereo channels. After a very short period of time, even a couple minutes, the left-channel's sinks become extremely hot to the touch while the right channel remains cold.
The audio output is correct and expected, a typical radio or aux music signal amplified in stereo. Sound on both channels is totally fine coming out of the speakers. I only noticed the heating asymmetry by accident.
I don't know that this is a problem that needs solving, exactly, but the heat in that area seems likely to reduce the life of the new left channel caps somewhat.
I'd like to understand if (1) this indicates a problem and (2) what might explain it? Could those power transistors be deteriorating unevenly with age? Could something else that feeds them be behaving strangely? (I've replaced all the electrolytics and a couple questionable looking film caps on this board, for what that's worth.)
Any insight or theories/pointers/assistance very welcome. I have a bench oscilloscope and can probe signals in an entry level kind of way if that's useful but not sure what I'd be looking for in this case since output seems fine.
Worth noting that the differential in heat remains over long durations-- the right channel does eventually (an hour?) become perceivably a bit warm to the touch, but the left channel becomes scorching very quickly and stays that way. (This is also true if the left speaker is not even plugged in, fwiw)
Photo of the board and image of the schematic for this board below. The left channel is the left half of the board, and the two left heat sink sections.
Schematic. Input from preamp at left, output to speakers at right. Left channel is top half of the diagram. T708 (and maybe T709? maybe T705?) appear to be the very hot transistors.
