Forgive me if "What kind of LED" is technically incorrect. I'm new to electronics and am trying to build a light (reference link attached below) for making videos. I have some LEDs which come standard in Arduino/RPi kits, but I don't believe they are capable of emitting enough light without burning out. I believe they are 3V/20mA 5mm LEDs.
What kind of LEDs are used in lights such as this?
  • \$\begingroup\$ Read the specs. Power consumption is 10W over 66 LEDs. That tells you the power per LED : the voltage is fairly well known (and in the datasheet) giving you a current. Find LEDs whose datasheet says they produce that colour and can handle that current. \$\endgroup\$
    – user16324
    Commented May 19, 2020 at 12:54
Most LEDs used for lighting are small surface-mount devices. They are soldered direct to a circuit board, which helps take the heat away. They are also a lot more compact.
You can even buy LED modules, with an array of LEDs already mounted on a circuit board and heatsink.
