Andy beat me to the wire-OR approach. Here is a variation.
Use 27 small signal diodes (1N914, 1N4148, etc.) and one common pull-down resistor. Depending on the headroom between the lowest high-level input voltage to be detected and the low-high transition voltage of whatever logic family you are using, it might be enough to simply connect the common node to a gate input. What are the lowest input voltage level to be detected, and the power supply voltage(s) available for the input circuit?
UPDATE:
This circuit illustrates the concept. It is not complete because many details are not yet supplied by the TS.
The 27 diodes and R1 form a wire-OR gate; when any input goes high, the voltage across R1 increases above the transition level of whatever is acting as a detector.
The nominal transition level for a TTL gate is approx. 1.8 V, which is far enough below the input voltage minus the diode forward voltage drop to be a reliable detection threshold. Note that if the downstream circuit is a bipolar TTL family (74xx, 74LSxx, etc.) the max value for R1 is relatively low.
CMOS families with a "T" in the descriptor (HCT, AC, etc.) also should work directly. Non-T CMOS families (HC, AC, etc.) and most 4000 series gates will not, because the transition level is approx (Vcc / 2), too close to the input signal voltage after a diode.
For a non-5 V input circuit, you'll probably need an analog comparator. The schematic shows the basic form. Missing are the operating voltages, a possible output pull up resistor, possible hysteresis, etc., because application details are not given by the TS.
