I have a BLDC motor driver that's powered at 24v DC. The control for this driver is via a line that modulates speed based on the voltage applied (between 0 and 24v) so a voltage divider using a pot seems like the simplest solution that works flawlessly for testing.
Now to actually implement this, what would be the best way to do this with a microcontroller? Using a DAC or a digital pot seems like a simple solution but options are limited at those voltage levels. Current requirements for the control line are low (10ma or less).
  • \$\begingroup\$ are you certain that the driver does not have digital control input? \$\endgroup\$
    – jsotola
    May 20, 2020 at 1:45
  • \$\begingroup\$ Yep, 4 wire driver, pwr, gnd, control and tacho \$\endgroup\$
    – rjds
    May 20, 2020 at 12:25
  • \$\begingroup\$ 0 to 24 seems odd... You have a spec sheet that says that? Most things analog are 0-10V, 0 to 5V, or 4-20mA current signals... \$\endgroup\$
    – MadHatter
    May 20, 2020 at 20:07
  • \$\begingroup\$ Surprisingly enough, it is. I tested it out under multiple conditions too. It takes full range input of 0 to Vss. In my case, the motor is rated for 24v hence the 0-24 range. \$\endgroup\$
    – rjds
    May 26, 2020 at 21:24
If your microcontroller does not have a DAC, you can generate high-frequency pwm, run it through a low pass filter and it is effectively an analog voltage.
Unfortunately if you're trying to get up to a higher rail voltage than your microcontroller pin output, then you could either first pwm a transistor in front of the filter with a pull down from a higher voltage rail, or use an op-amp after your filter.
A pull up to drive a filter on 24V will eat a lot of power, you might be better off using an op-amp amplifier out of a DAC or 0-5V PWM run through a low pass filter... Below is a schematic to give an idea, although you will notice if you simulate it is more like 0-22V due to the 4.7k pullup resistor not driving the filter well.
Use a DAC followed by a non-inverting op-amp based amplifier.
I'd go with controlling the motor with a transistor driven by a PWM signal
  • \$\begingroup\$ It's a brushless motor and OP already has a driver \$\endgroup\$
    – DKNguyen
    May 20, 2020 at 0:56
    \$\begingroup\$ I think MadHatter and Scott are suggesting using filtered PWM in lieu of a DAC. \$\endgroup\$
    – TimWescott
    May 20, 2020 at 14:59
