I'm trying to replace a part on my camera and need to disconnect a connector that looks like this:
From what I understand, they're extremely fragile and so I don't want to accidentally break anything (as many others unfortunately did when working on this camera).
Whats the correct way to unlock this connector?
Which part of the connector unlocks? The bottom or the top part?
zif
there are also non-zif ffc connectors, from which you just pull out. If you pull a little on the cable and it comes off, then it is not a zif connector. \$\endgroup\$
