The Setup
I'm using a 74HC4051N multiplexer to interface with several analog sensors. I'm using a Wemos D1 Mini to read Z (output from the mux) using the Wemos ADC.
I've only illustrated one (of 4) TMP36 temperature sensors. I'm also monitoring the 12 V line from the battery. I use a 1.6 M ohm resistor to bring the 12 V down to 3.3 V at A0 in conjunction with the internal potential divider of the Wemos.
circuit diagram
The Problem
If I disconnect all sensors (y0-y7) and iterate through all mux addresses, reading off values I get something like the following:
Address 0: Val 12
Address 1: Val 8
Address 2: Val 9
Address 3: Val 13
Address 4: Val 12
Address 5: Val 15
Address 6: Val 10
Address 7: Val 8
The low values are expected, the Wemos ADC is a bit noisy.
If I now connect the 12 V sense line only to say y1, the readings look like this:
Address 0: Val 476
Address 1: Val 802
Address 2: Val 436
Address 3: Val 410
Address 4: Val 469
Address 5: Val 398
Address 6: Val 401
Address 7: Val 451
The 12 V reading (value of 802) on address 1 looks to be correct. The Mux chip appears to be fine as using the TMP36 sensors on their own I see the expected output:
Address 0: Val 240
Address 1: Val 920
Address 2: Val 786
Address 3: Val 870
Address 4: Val 12
Address 5: Val 15
Address 6: Val 10
Address 7: Val 8
What am I missing? Why does it appear to raise the ground level of the ADC?
When anything other than address 1 is selected Y1 will attempt to go to +12V. This will exceed the input rating of the 74HC4051 and almost anything can happen.
Most analog multiplexers do not allow any input voltage to go outside the supply rail limits or current can leak through unintended paths within the device.
It will work correctly when Y1 is selected because the voltage is within range because of the load of the resistors in the D1.
It looks like the 12V is leaking to all the other inputs under the fault condition.
If you want good accuracy I would not recommend relying on the resistor values of the D1 Mini. I would instead use a relatively low-value resistor potential divider to bring down the voltage to one acceptable to the D1.
The resistor values in the potential divider would need to be much lower than the values in the D1. Say 10K ohms.
If you just want to avoid the fault you could use a diode clamp to +5V to avoid the overvoltage condition.
  • \$\begingroup\$ ah perfect answer thanks. I completely overlooked Y1 going to +12v when the mux 'disconnects' from that channel. I assume the resistors in the separate potential divider need to be low(ish) to minimise the parallel resistor effects? \$\endgroup\$
    – YMDW
    Commented May 21, 2020 at 8:30
