MY ATTEMPT
I found a formula for the DC transfer function for the flyback converter:
$$\frac{V_{out}}{V_{in}}=\frac{N_s}{N_p}\cdot \frac{D}{1-D} $$where \$ \frac{N_s}{N_p} \$ must be the ratio between the number of turns of the two coil-inductors, and \$ D\$ is the duty cycle. And since we know \$V_{out}\$ and \$V_{in}\$, we just need to find \$\frac{N_s}{N_p} \$, and then we can solve the equation with respect to \$D\$.
However, I can't seem to find any way to find the \$\frac{N_s}{N_p}\$-ratio, when I only know the inductances of the coils. How can I arrive at the value for \$\frac{N_s}{N_p}\$, so that I can solve the original equation?
I hope someone can help me with this.
Edit 21/02-21
Here I am, one year later going through this problem again, to see if I can solve it. However, even with Andy aka's formula \$\frac{N_s}{N_p}=\sqrt{\frac{L_s}{L_p}} \$ I am unable to solve it.
$$\frac{15 \text{V}}{110\text{V}} = \sqrt{\frac{16.2 \cdot 10^{-6}\text{H}}{1.28 \cdot 10^{-3}\text{H}}} \cdot \frac{D}{1-D} \Rightarrow D=45.20\% $$ But the correct answer is \$D=46.15 \% \$ (according to my instructor). I even tried to take into account any mutual inductance assuming zero flux leakage and 100% magnetic coupling $$M=\sqrt{L_sL_p}= \sqrt{16.2 \cdot 10^{-6}\text{H} \cdot 1.28 \cdot 10^{-3}\text{H}}=0.144 \text{mH}$$ But that didn't get my anywhere.
Final edit
After approximately one year, I finally solved the problem. Since \$V_{in} \$ is in RMS, you have to multiply with \$\sqrt{2} \$ to get the peak voltage.
$$\frac{15 \text{V}}{110\text{V} \cdot \sqrt{2}} = \sqrt{\frac{16.2 \cdot 10^{-6}\text{H}}{1.28 \cdot 10^{-3}\text{H}}} \cdot \frac{D}{1-D} \Rightarrow D=46.15\% $$
