If we increase the collector resistance then how will the collector current change? I understand the circuit behavior if i neglect early effect but when i try to include it that is allow Ic to vary with Vce i get lost because everything changes and it's as if i lose the grip on all variables.
P.S I'm a self studying person solely dependent on internet and books, so I hope that this question isn't blocked because it may look like a homework problem. Thanking you in advance.
Yasir Sadiq...here is my short explaantion:
When modifying the collector resistor (without changing the input signal) the collector voltage - and with it - the voltage Vce changes. For example, a reduction of Rc will increase the voltage VCE across the resistor.
This voltage increase will increase the depletion zone of the reverse-biased B-C pn junction and consequently reduces the width of the remaining base region associated with the forward-biased B-E pn junction. As the result, the E-field within this region will rise (constant B-E voltage) and a larger portion of the emitted charged carriers will arrive at the collector (Ic rises somewhat). This effect is called "base-width modulation" and is the cause of the Early effect.
  • \$\begingroup\$ Thanks LvW, how can you say that "a reduction of Rc will increase the voltage VCE across the resistor".This is the essence of my question! \$\endgroup\$
    – Kashmiri
    May 24, 2020 at 0:23
    \$\begingroup\$ .....sorry for my typing error: Of courser, it should read "..across the TRANSISTOR". There is a voltage division between Rc and the C-E path. Hence, a reduction of the voltage across Rc will cause a rise in VCE. \$\endgroup\$
    – LvW
    May 24, 2020 at 8:32
  • \$\begingroup\$ you said " Hence, a reduction of the voltage across Rc will cause a rise in VCE " now this rise in VCE cause ice to increase due to early effect,then this larger IC current leads to a larger drop via the resistor and hence decreases VCE,which then leads to a decrease in ICE . Now this decreased IC leads to a lesser drop via the resistor hence increasing VCE, Which then lead to an increase in ICE.... And we get stuck in an infinite loop. This is what confuses me. I hope I'm clear enough, and thanks for your effort to help dear. \$\endgroup\$
    – Kashmiri
    May 24, 2020 at 12:00
    \$\begingroup\$ OK...I know what you mean...but: Let us assume that we increase the Rc by 25% and the voltage acros Rc changes also by 25%. When the VCE had before app. the same value, it will increase by 25%. However, the corresponding increase in Ic will NOT as large as 25%...perhaps only 5% ....Have a look on the small slope of the curves Ic=f(VCE)... \$\endgroup\$
    – LvW
    May 24, 2020 at 12:24
    \$\begingroup\$ Yasir S....there are some physical effects which cannot be solved "exactly" using math. \$\endgroup\$
    – LvW
    May 26, 2020 at 7:40
To a first approximation, the transistor is a current source, so changing the collector resistor does not change the current, only the collector voltage
We can model the transistor as either a base current controlled current source (hFE, beta), or a base voltage controlled current source (gm). Which model is most convenient depends on whether we're biassing the transistor, or using it as a small signal amplifier.
To a higher order approximation, the collector current will change slightly with the collector voltage. You've already mentioned the Early effect, so you understand that.
For very high values of Rc, where V+/Rc exceeds the current the transistor is trying to sink, the transistor will be saturated, and neither collector voltage nor current will change.
  • \$\begingroup\$ Thank you dear Neil, but i was looking for a more detailed description of how Ic changes with Rc. \$\endgroup\$
    – Kashmiri
    May 23, 2020 at 17:23
    \$\begingroup\$ @YasirSadiq - If you are looking into the details then read about the Early Effect. It is a second order effect and for most designs it can be ignored. \$\endgroup\$ May 23, 2020 at 18:29
    \$\begingroup\$ @YasirSadiq - for design purposes the early effect is included in the apparent output resistance - Ro. Without the early effect it would be infinite. So it acts as a resistor in parallel with the collector to emitter. \$\endgroup\$ May 23, 2020 at 22:18
    \$\begingroup\$ @YasirSadiq - agreed but the slope of the current vs collector voltage still acts like a resistance. \$\endgroup\$ May 24, 2020 at 16:29
    \$\begingroup\$ @YasirSadiq If you try to solve it strepwise like that, yes, it's an infinite series (not an infinite loop), but like the infinite series 1 + 1/2 + 1/4 + 1/8 ... it sums to a finite result. It's far easier to write down the implicit equation, and then solve it, that's what modelling the effect as an extra resistor on the collector is for. In hybrid parameters, it hoe, the 'output impedance'. \$\endgroup\$
    – Neil_UK
    May 26, 2020 at 5:13
