I think I'm really not so good at soldering.
All places say it's it's fairly easy to hand solder LQFP ICs, but for me it isn't... On videos the tin nicely melts between the pins, and do not create solder bridges.
I tried today a board with 0802, 0603, 0402, SOT23 and SOIC16 and at least under a microscope (cheap one) it looked not great, but good enough. I couldn't measure everything but all 0802, 0603 and 0402's were soldered ok.
Than I tried my (sub) goal: to solder a LQFP48 (STM32F103) on an adapter board and this went horribly wrong.
I used my rework station to have it removed, which worked, but I doubt I can use both the IC and adapter board again. Also, I couldn't make any useful picture.
However, I maybe you can give some advice what to do better next time, and maybe how to fix it. I have a clue: I think I use too much solder, but it's so hard to know how much to use (or when there is accidentally a bit too much on the soldering tip).
What I do is:
  • I use 0.5 mm solder iron (with lead)
  • I use a fairly small wedge type tip
  • I used quite some flux (flux pen)
  • 350 degrees Celcius (650 degrees fahrenheit)
  • Put a bit of solder on the tip
  • Put it on the adapter board
  • Tack the first pin
  • Slide as carefully as I can from the yellow spots in the picture below, outwards. However, this results sometimes in a soldering bridge between two (or more) pins, i.e. the yellow spots (which extend over the pins itself which is ok, but not between the pins).
  • Sometimes I create accidentally solder bridges at the red spots. This is even worse, as they are 'higher' above the adapter board.
  • In all cases, I cannot use my soldering iron to remove it; the solder just will not find its way to one of the pins (especially near the red bridges)
I tried solder wick, but as the yellow spots are lower than the pins, it doesn't work. For the red solder bridges it's even worse as they are higher.
Another problem might be that the tip 'wiggles' a little bit, however the solder fairly easy melts (and I could do the practice board without any problems).
I don't mind if I ruin 1 or 2 ICs now, however I want later to order PCB's where I want to solder STM32's onto (or at least one on a board), so at that time I hope I be able to.
Below are (as requested) pictures of the solder tin I use and flux pen (both chinese).
The solder tin has the following description: 0.5 mm, 63/37 solder flux 2% Rosin core.
    \$\begingroup\$ Use flux generously. It makes life a lot easier. Some pics of the actual solder would be helpful for diagnosing the issues. \$\endgroup\$
    – Wesley Lee
    May 25, 2020 at 23:27
    \$\begingroup\$ I don't know much about soldering alloys and so on, but my experiences with solder wire/pastes from China are pretty bad. I've tried stuff from Brazil, US, Europe, leaded and unleaded and while they have their differences, they are far superior than the chinese products that I have tested. I'm sure there are good alloys from China as I have plenty of PCBs that were assembled there that are great, but the wires that I did test are practically unusable (if compared to alternatives). p.s. (I meant solder "work" (i.e. the soldered IC), so we can identify bridges/shorts and so on) \$\endgroup\$
    – Wesley Lee
    May 25, 2020 at 23:47
    \$\begingroup\$ as long as your initial alignment is correct repeatedly adding and removing solder should do the trick. and use flux. sometimes just enough to flux and wipe the smallest of solder beads on the tip and float it over over the pins. lengthwise for yellow dots and away from the ic for red dots. yellow should be no problem. red is harder \$\endgroup\$
    – DKNguyen
    May 26, 2020 at 1:06
    \$\begingroup\$ There are lots of questions on this here already. You are probably using too small an iron tip and not enough flux, as with a large iron and good flux you'll get surface tension clearing the more minor bridges and helping good fine pitch braid wick up any that do not clear on their own. Your flux pen is not sufficient for this, at least not beyond the initial attempt. Something like rosin will make a mess, but it is highly effective. \$\endgroup\$ May 26, 2020 at 1:25
    \$\begingroup\$ @MichelKeijzers Tip size is quite subjective. I use the smallest one I have for fine pitch, it's personal preference. Generally speaking, bigger tips are better since they heat quicker, but just not for fine pitch. \$\endgroup\$
    – Lundin
    May 27, 2020 at 14:59
Disclaimer: a lot of soldering the techniques and best advise are subjective. Use whatever tools that work best for you - my advise below is just what I personally prefer.
Also disclaimer: I'm not a professional (I'm actually a software dude), though I have gone through IPC training and also mounted a whole lot of SMD prototype boards over the years.
You seem to be on the right track for the most part. The most common problem is using too much solder.
General advise for SMD and fine pitch:
  • Use thin solder - always use 0.25mm for small SMD components! This is probably the most important advise I can give you.
  • Use leaded solder if that's an option. It's much easier to work with than RoHS solder, and also makes it easier to spot cold joints.
  • Use the finest tip you got. I personally prefer the bent tips for small SMD, but that's mostly personal preference. Just don't use some elephant-sized tip that ends up heating multiple pins/pads at once when you don't want to, because that's a certain way to get bridges.
  • Make sure the tip is perfectly clean each time before you solder a pin. Solder residue often leads to too much solder. You won't be able to avoid getting solder on the tip when you apply it anyhow. I prefer a wet sponge for cleaning fine tips.
  • Remove the tip away from the component horizontally, along the board's surface. That way you won't make a mess with any solder residue that has ended up on the tip. If you just lift the tip straight up, it is easy to drag solder over to adjacent pins. Also, moving the tip straight up might create evil little "antennas", as the solder will follow the tip if all of the flux core from the solder has vaporized.
I mount LQFP by hand like this:
  • Mount fine pitch components early on, so that you don't have to dodge surrounding components when soldering. Usually LQFP are the first component(s) that I mount on the board.
  • Carefully align the part with the pads, check that it is straight and aligned on all four sides. Most of the work mounting these is getting them in place.
  • Secure it temporarily by holding it in place with tweezers or other tool (depending on part size). Tape might also work but I don't use it.
  • Solder one single pin in one corner of the part. Place the tip where the toe of the pin meets the pad.
  • Once again, check that the part is aligned with all pads, correct it if it isn't and hold it in place when it is. You can carefully move it slightly, even though one pin is already secured.
  • Solder one pin in the opposite corner to the one you just did. Check again that everything is aligned.
  • Go back and re-do the first pins, so that there is no mechanical strain on the joints, in case you nudged the part around.
  • Solder one pin in each remaining corner, so that it is held in place in all 4 corners. Re-do them if you think there might be mechanical strain on them.
  • Now do each side of the part, from left to right (if you are right-handed). I do this one pad at a time, applying a tiny bit of solder on each, preferring too little over too much. This way it doesn't matter if you accidentally heat the neighbouring pin to the right, but you should avoid touching the already done one to the left.
    Others like to just toss in a lot of solder along one side, and then correct with flux + re-heat later, but I find that harder to do personally. If you do, you should preferably use a wider tip.
  • Fix bridges by applying flux, then try to heat both pin/pad pairs that are bridged at once. Remove the tip by dragging it along the pads. This way, any superfluous solder either wets along the pad as it should, or gets carried away from it by ending up on the tip.
  • If you truly mess up and use too much solder, it is possible to use your finest solder wick braid to clean up, but you have to be very careful. You will end up heating multiple pins, so afterwards you have to re-do not just the pins that had the bridge, but likely also surrounding ones.
  • \$\begingroup\$ I tried yesterday again using a smaller tip (which is still more than a few pins width, going to try a round small tip this evening. Also I used solder paste (flux), which worked better than the flux pen, but I will try first without. I am sure the biggest problem was indeed too much solder, so I'm going to be very careful this evening when trying again. Also my wick is not fine, so I'm sure that's the reason the wick doesn't work well. \$\endgroup\$ May 27, 2020 at 15:12
  • \$\begingroup\$ @MichelKeijzers Get the 0.25mm solder if you haven't already. It's very hard to do fine pitch with thicker solder than that. \$\endgroup\$
    – Lundin
    May 28, 2020 at 6:29
    \$\begingroup\$ @MichelKeijzers Maybe start with 1.27mm or at least 0.65mm pitch. 0.5mm is the hardest one. And well, some irons can't deliver enough heat to the smallest tips. What heat are you using and what brand of soldering iron? You could perhaps try to turn the heat up towards 450 degrees. Also keep in mind that these thin tips tend to have a shorter life time. \$\endgroup\$
    – Lundin
    May 29, 2020 at 13:53
    \$\begingroup\$ @MichelKeijzers (Also, professional assembly companies are probably happy to help out for a small fee, doing this the pro way with an oven. I prefer to use them for the truly nasty stuff like fine pitch QFN or BGA.) \$\endgroup\$
    – Lundin
    May 29, 2020 at 13:56
    \$\begingroup\$ @MichelKeijzers Heat isn't good for the part, but if you notice that the joint won't even wet then maybe the temperature out in the tip isn't enough. I've had this problem not to long ago when using thin tips on a mediocre iron set to 350 degrees - the actual tip heat was probably something far lower. Could of course also be a bad/polluted tip etc, in which case more heat won't help. \$\endgroup\$
    – Lundin
    May 29, 2020 at 14:05
