I have a Sony Sony DSX-A110u which is a car stereo having 4*55W Speaker out and a Sub-woofer out.
The subwoofer-out port it a female RCA jack. which looks like this
I am using the sub-woofer out jack to feed in a another stereo-subwoofer amplifier which takes in 3 wires Left, Right & Ground as a input
I have given input to the other amp. like this
THE PROBLEM
As you can see the car's stereo subwoofer output both channel separatel via RCA jack so naturally, To give input to my other amplifier, I joined the ground pin of RCA cables to make it 3-pin stereo format.
Now the problem is, As soon as I join the ground wire of the both RCA out, The volume output of other subwoofer amp gets really low and makes a Tick-Tick noise once every second, Like some digital signal has been passed with the audio signal. Its more noticeable in higher volumes.
The tick-tick noise continues even when nothing is playing on the stereo.
The amplifier works fine in MONO mode otherwise! (Using just 1 RCA jack)
5200 1943 Mosfet
amp and it is having a 3-pin input in form a a 3.5mm female jack. In this case what I can do? \$\endgroup\$ – GeekWithGlasses May 28 '20 at 21:06
