I was musing about electric motors after seeing one randomly on TV, and there's something I'm must be remembering incorrectly.
It's just a thought experiment, so I'm imagining some theoretical DC electric motor, with a constant RMS current/voltage feeding in, and some constant load on it causing it to spin at some constant rpm and produce some constant torque.
Since voltage x current = electrical power = motor's mechanical power, that's the cap on how much you can get out of the machine.
But I remember that the greater the difference in rotational speeds between the rotor and stator fields (slip?), the more force/torque will be exerted on the rotor.
So in the hypothetical, if the motor is doing its thing and is stable with the load, if you suddenly increased the frequency of the input voltage/current, that in my mind would result in suddenly increasing the difference in relative rotational speeds of the stator/rotor, meaning the stator would feel more force/torque on it, which would make it want to speed up and catch up to the stator field, speeding up the load.
But only frequency changed and not how much electrical energy is entering the device, so there's no way that's possible! So I MUST be wrong, I just don't see where the error in my thinking is...
What's wrong with my thinking, and what would actually happen if you increased the frequency like that?
(I'm not an electrical person by trade, so there's a limit to my knowledge of concepts/terminology.)
[EDIT: I failed to mention that by "frequency", I'm referring to how DC motors can be controlled with pulse width modulation, and those pulses go in at some frequency. Otherwise it wouldn't make sense to talk about "frequency" with direct motors]
