I want to design this circuit using the Verilog HDL. However, I can't make a feedback part well.
Here is my code.
`define TAP7 7'b1000001
`define TAPS `TAP7
module TEST_LFSR_2(Clock,Reset,Y);
    parameter Width=7; /*bit parameter*/
    input Clock,Reset;
    output [Width-1:0]Y;
    wire [Width-1:0]Taps;
    integer N;
    reg [1:0] semiFeedback;
    reg Bits0_Nminus1_Zero,Feedback;
    reg [Width-1:0]LFSR_Reg,Next_LFSR_Reg;
assign  Taps [Width-1:0]=`TAPS;
always@ (negedge Reset or posedge Clock)
    begin : LFSR_Register
        if(!Reset)
            LFSR_Reg=0;
        else
            LFSR_Reg = Next_LFSR_Reg;
    end
always@(LFSR_Reg)
    begin:LFSR_Feedback
        Bits0_Nminus1_Zero=~| LFSR_Reg[Width-2:0];
    for(N=Width-1;N>=1;N=N-1)
                Next_LFSR_Reg[N]=LFSR_Reg[N-1];
                if (Taps[N]==1)
                    Feedback=^LFSR_Reg[N];
                Next_LFSR_Reg[0]=Feedback^Bits0_Nminus1_Zero;
    end
    assign Y=LFSR_Reg;
endmodule
I want to make an N-bit LFSR. After checking the TAPS's bit that has 1, I want to XOR each bit that has 1. However, I don't know how to do it.
I'm not sure where you're going with all of that Verilog code, but your diagram basically boils down to the following statements:
wire [7:0] mask = 8'b01110001;
reg [7:0] LFSR_Reg;
always @(posedge Clock)
  LFSR_Reg <= Reset ? 8'b10000000 : {^(LFSR_Reg & mask), LFSR_Reg[7:1]};
Use the power of the language to avoid unnecessary work!
  • \$\begingroup\$ Except you should use non-blocking assignment, <=, inside the sequential always block. \$\endgroup\$
    – Matt
    May 29, 2020 at 4:35
  • \$\begingroup\$ @Matt: Technically, since it's a single statement and not a block, the type of assignment makes no difference at all. But as a teaching example, you're right -- I should establish the correct habit. \$\endgroup\$
    – Dave Tweed
    May 29, 2020 at 10:44
