I want to create a mounting hole with vias around it. I don't know how to approach it so I've tried to do it on my own. I'm using OrCAD PCB Designer.
I have created a mounting hole padstack with desired diamater, solder mask, antipad and so on. Additionaly, I designed a padstack of via which diameter is 0.4 mm. Now, I want to combine those 2 elements. I mean, I want to place 8 vias around the mounting hole. I deducted that that footprint must be created as a Package symbol. I've added mounting hole as a mechanical element and 8 vias as an electric symbol.
For now, it goes like this.
I got many DRC errors. How can I fix that problem?
EDIT: In 3D, it looks like this
It is like it was meant to be.
Preliminary symbol in the library is like that. I want to add a Pack Short parameter to merge the pins into one.
  • \$\begingroup\$ What does your symbol look like - show a schematic picture of your symbol please. \$\endgroup\$ – Andy aka May 29 '20 at 13:00
  • \$\begingroup\$ @Andyaka you mean, the symbol in the library in OrCAD capture? \$\endgroup\$ – Marco Svizzeri May 29 '20 at 13:13
    \$\begingroup\$ You might try making your mounting hole a pin like the others. Then make the padstack for the hole just big enough so that its copper doesn't overlap the via copper then, add a copper circle to encompass them all. You'll need to join all the 9 pins up with connections at the schematic level of course. \$\endgroup\$ – Andy aka May 29 '20 at 13:23
