First of all I am a newbie in electronics.
I am building some weight scale applications using (as seen everywhere) load cells wired to a HX711 ADC and a ESP8266. I am now giving a try to the Texas Instruments CC1312R MCU (datasheet), still work in progress :)
The CC1312R features include a 8 channels 12-Bit ADC. My needs require at least a 16-Bit ADC.
Since this internal ADC provides 8 channels, I was wondering if I could somehow serialize them to achieve some extra bits resolution, thus not having to use any external ADC, is that possible?
Thanks for your help!
  • \$\begingroup\$ I think you are talking about measuring the same signal with all 8 channels and averaging the measurements. I doubt that will be any better than just averaging the measurements from one channel. You can sometimes achieve improved resolution by averaging, but I don't think it will be good enough for 16 bits. \$\endgroup\$
    – Justin
    Commented May 29, 2020 at 14:28
    \$\begingroup\$ It's just one ADC being multiplexed to all 8 channel so sampling on multiple channels won't do anything. \$\endgroup\$
    – DKNguyen
    \$\begingroup\$ In my experience, you might get an extra 2 bits of resolution, but the effective number of bits for the 12 bit channel is going to be less than 12 in the first place. analog.com/media/en/training-seminars/tutorials/MT-003.pdf \$\endgroup\$ Commented May 29, 2020 at 14:40
    \$\begingroup\$ Related: Accuracy of RMS of sine measured from N samples of ADC conversion. You can increase the effective resolution by combining multiple samples, but ONLY to the extent that the errors in the measurements are uncorrelated. And the improvement scales with the square root of the number of samples, so for each additional bit of resolution, you need to quadruple the number of samples. \$\endgroup\$
    – Dave Tweed
    Commented May 29, 2020 at 14:56
  • \$\begingroup\$ @DKNguyen I understand, and what about piping the ADC channel to the internal DAC and then refeed an ADC channel (suggested here)? \$\endgroup\$
    – Cinn
    Commented May 29, 2020 at 15:16
If you dither the signal and average more than 256 samples you can get some apparent resolution (not accuracy) increase, but frankly you’d be far better off ignoring the on-chip ADC and using an external ADC designed for load cell applications.
The one you mention (HX711, made by Avia in Xiamen, China) is only about 40 cents (24-bit delta-sigma with on-board PGA and bandgap reference) so it's not like it's going to break the bank!
  • \$\begingroup\$ Things like this quickly gives diminishing returns.. Though the ultimate example is the sigma-delta converter magically turning 1-bit into a nice 16-bit output. \$\endgroup\$
    – pipe
    Commented May 29, 2020 at 14:43
  • \$\begingroup\$ For uncorrelated noise the maximum theoretical improvement is the square root of the number of samples, so 256 potentially gives 4 bits of improvement. Reality is going to be a lot more disappointing, especially with a typical crummy on-chip MCU ADC peripheral. \$\endgroup\$ Commented May 29, 2020 at 14:54
    \$\begingroup\$ Delta-sigma is more than just about averaging. Noise shaping and post filtering are important parts of the process. \$\endgroup\$
    – Dave Tweed
    Commented May 29, 2020 at 14:59
