I'm trying to run ads7924 using stm32f series.
But i2c does not work so I check the i2c line.
Between 0R, MCU side 3.3V but ads7924 side 0V. I set pull up setting of MCU internally .
What is the problem? below is the circuit i designed enter image description here
    \$\begingroup\$ If you have 3.3V at the MCU end of the SDA line, and 0 V at the ADC, you must have a broken connection (open circuit) between the MCU and ADC. \$\endgroup\$ May 29, 2020 at 23:04
    \$\begingroup\$ Is 0R a zero ohm resistor? If so, you cannot have different voltages on each side. \$\endgroup\$
    – Annie
    May 29, 2020 at 23:05
    \$\begingroup\$ I see no ground connection on MCU side. Is MCU ground connected to ADS7924 DGND? \$\endgroup\$
    – glen_geek
    May 29, 2020 at 23:25
    \$\begingroup\$ "I set pull up setting of MCU internally" the internal MCU pull-ups are nowhere even close to the I2C slew requirements \$\endgroup\$
    – Maple
    May 30, 2020 at 0:17
  • \$\begingroup\$ Annie - yes.. its 0R. I designed it to debug point.. \$\endgroup\$ May 30, 2020 at 5:23
