I'm designing a D_FF from JK_FF.
The circuit I'm implementing is , as shown in the figure :-
Verilog Module Code :-
`timescale 1ns / 1ps
/* Conversion of a JK Flip Flop to a D Flip Flop
    Connections are "J = D" and "K = ~D"
module d_ff_from_jk_ff (q,qbar,rst,clk,d);
        output reg q;
        output qbar;
      input rst, clk;
      input d;
 wire d_n;              // Inverted version of D input //
 assign d_n = ~d ;
 jk_ff d_converted(q,qbar,clk,rst,d,d_n);
endmodule
/******************************************* JK Filp FLop Module ************************************/
 module jk_ff(q,qbar,clk,rst,j,k);
          output reg q;
          output qbar;
          input clk, rst;
          input j,k;
          assign qbar = ~q;
always @(posedge clk)
    begin
          if (rst) q<=1'b0;             // Synchronous Reset //
          else
            case ({j, k})
                2'b00: q<=q;            // Previous Value //
                2'b01: q<=1'b0;
                2'b10: q<=1'b1;
                2'b11: q<=~q;           // Toggle //
         endcase
end
endmodule
Testbench Code :-
module testbench;
    // Inputs
    reg rst;
    reg clk;
    reg d;
    // Outputs
    wire q;
    wire qbar;
    // Instantiate the Unit Under Test (UUT)
    d_ff_from_jk_ff uut (
        .q(q),
        .qbar(qbar),
        .rst(rst),
        .clk(clk),
        .d(d)
    initial begin
    clk = 1'b0;
    rst = 1'b1;
#10  rst=1'b0;
end
always #5 clk=~clk;
    initial begin
        d = 1;
        #50;
        d = 0;
        #50;
        d = 1;
        #50;
        d = 0;
        #50;
#100 $finish;
    end
endmodule
In the simulation output, the value of Qbar is changing as expected, but the waveform of Q is constantly held at a "X" (don't care) condition.
Can anyone tell me where I've gone wrong and what correction is to be made ?
I get a compile error with Cadence. In d_ff_from_jk_ff, change:
    output reg q;
to:
    output q;
After I fix that, q is only X for the first 5ns, then I see it toggle between 0 and 1 thereafter.
Here is the error I got:
xmelab: *E,RANOTL : A reg is not a legal lvalue in this context [6.1.2(IEEE)].
  • \$\begingroup\$ This changed worked and I got the ouput Q. But without the change, with the same code as above , I was able to get the output when I used EDA Playground online . So is this got something to do with the simulator tool ? \$\endgroup\$ May 31, 2020 at 14:26
    \$\begingroup\$ @AbhishekChunduri: Yes, as we've seen, different simulators sometimes produce different results. I 1st tried with SystemVerilog (IEEE 1800) enabled on my versions of VCS and Cadence, and I didn't even get warnings. And I didn't see the X you saw. So I defaulted back to IEEE 1364 mode, and then I saw compile errors on both simulators. \$\endgroup\$
    – toolic
    May 31, 2020 at 14:30
