Ok, it may look a bit confusing. I am specifically talking about STM32 MCUs, or even more specific, STM32F103C8T6. I did some amount of reading, but could not find the answer to this.
Let's say I want 4 PWM signals each at 50 Hz but all with different duty cycles. In such a case will I need 4 distinct timers, or can I use one timer with 4 channels? I mean can each channel of same timer be configured with different duty cycle?
  • \$\begingroup\$ What did you think a channel was for if not this? The answer, by the way, is in the fact that each channel has it's own register. \$\endgroup\$
    – DKNguyen
    Jun 2, 2020 at 20:07
  • \$\begingroup\$ @DKNguyen I am no sure but maybe for using same timer for both PWM and input capture for example. \$\endgroup\$
    – muyustan
    Jun 2, 2020 at 20:11
  • \$\begingroup\$ Fair enough. But then what if there were 4 channels (which there should be on most timers). \$\endgroup\$
    – DKNguyen
    Jun 2, 2020 at 20:12
  • \$\begingroup\$ *Its own count register \$\endgroup\$
    – DKNguyen
  • \$\begingroup\$ The count register determines when a channel triggers (for output compare) or what timer count it captures (for input capture). \$\endgroup\$
    – DKNguyen
    Jun 2, 2020 at 20:17
That's why timers have multiple channels, to generate multiple PWM signals with same timer. If you use multiple separate timers, their output may not be synchronized.
  • \$\begingroup\$ ok, this answers my question, but, what about frequency? is it common for every channel of a timer? or can be different? \$\endgroup\$
    – muyustan
    \$\begingroup\$ @muyustan Frequency is common because they all run off the same clock and pre-divider so all channels count at the same time. \$\endgroup\$
    – DKNguyen
    Jun 2, 2020 at 20:14
    \$\begingroup\$ All channles run with a single timer so they must have identical frequency. \$\endgroup\$
    – Justme
    Jun 2, 2020 at 20:16
  • \$\begingroup\$ @DKNguyen thank you both. \$\endgroup\$
    – muyustan
