I have a 500W (230V) cartridge heater element and a K-type thermocouple. I want to use the feedback from the thermocouple to be able to vary the temperature of the cartridge heater. I have no concerns about being able to implement the thermocouple circuitry and software, however I have never used a high power heating element before.
I'm looking into the control of the element. I personally don't have an issue with an on-off control (as in, I'm okay with applying some hysteresis and having, say +/- 10°C from the desired value, or using PWM), however maybe there are some other considerations as to why this wouldn't be a good idea (switching life cycles for example). If there is a component to safely vary the power to the heating element, so I can implement PID for example, then I would also be interested in that.
As I want to control the heating elements from a microcontroller (preferrably 3v3, but can level shift to 5v if needed), I've been looking into relays. However, I am struggling with the power requirements - from what I find, 500W seems to be a lot of power for a PCB based relay (although since I've never used a relay before, maybe I am misinterpreting the specifications). I'm also concerned about the actual traces on the PCB - I'd much prefer to have the relay controlled by PCB traces but the heating elements just connected to the relay by wires, if such a device exists.
I've looked into latching, non-latching, solid state relays, SCRs, triacs, but I feel like the more I look into it, the less sure I am. I'm now at the point where I feel like there must be a standard way to do this, but I'm just getting lost in the sea of options.
So, is there a standard circuit/device to safely control the temperature of 500W (230V) heating element using microcontroller-level voltages? The cheaper/simpler method is usually better in my eyes, as long as it's safe.
EDIT:
Thanks all for the comments and answers so far. Looks like I'll go with some type of relay, and possibly some backup protection if I want to use a latching relay. One of the main issues I'm having with finding a suitable relay is geting the specifications correct. For example, the following is taken from a relay datasheet:
The first thing I see is that max switching voltage and max switching current are both high enough - great. Then I saw the rated load box, when confirms this. However, what confuses me is the 'Max. switching power' box. I'm already a little bit hazy on the difference between VA and Watts, but the fact that at has a maximum of 300W, while my element is rated at 500W, confuses me. Can anyone help explain this?
