We know that it makes no difference whether a resistor is placed "before" or "after" an LED in a circuit.
Is there a commonly used convention that encourages one or the other?
Consider the possibility of a momentary short from one of the LED leads to ground (ground could be connected to the chassis)- perhaps it causes no problem if there is a remote resistor connected to Vdd but, if the LED is connected directly to Vdd, the short instantly destroys the LED. Or it shorts out the power supply.
There may be other similar situations you can come up with. But really electrically it makes little or no difference one way or the other until you invoke such possibilities.
